I've heard of the cap coming out which is part of why I went with an external spring, plus it's stupid easy if you find the right spring... I just found a spring that fit around the splines, pushed against the center shaft and the hose clamps on the boot hold the spring in place, easy peasy...
I didn't get anywhere on the transmission today, here in a few minutes I'll go finish pulling the old master cylinder (just have the 3 bolts left...) then see about bleeding the new master cylinder with my spare hose... it turns out it was just the broken plastic clip deal on the old hose, I needed to push harder at the ends... the old hose had been wearing on the pinch weld on the cab anyway and I think it is about to the point of wearing through so good time to change it anyway, I need to change the body mount bushings, they're about shot so the gap between cab and frame is small... I'll protect that area this time though.
I put 3 of the tires from my spare set on the parts '92 so I could get it off the trailer, I pushed and the wife rode it down and braked
, then tried to pull a stump with the F350 but it's too muddy... then we put the camper on the back so we can go camping next weekend.
Also made some pieces of angle iron to put a lift kit on the bottle area of my welding cart, but I decided the Ranger needs to be done first so I have more area to work...
