- Feb 8, 2022
- Saint Paul, MN
Well said. I don't have 4WD or limited slip, so I keep the smaller stock tire as a spare.yes on mine the 265/75R15 steel belted with white outline letters is oem, Ford says so ("Research Team") also Oasis report says so.
I'm missing door sticker too and have all the info to re-create it except the spring codes and front/rear grosses and reserves.
But the spare is 235/75R15 that's normal, the larger tire doesn't fit under the truck, at least Ford says so also people have confirmed this.
What size is your spare that -might- infer what was oem size on your truck since chances are if they were oem 225's they wouldn't have put a 235 under neath, it'd be a 225 (probably) if that was oem size.
It doesn't really matter.... just saying.
Well it matters if the tires are different diameter and you put the spare on the front and are in 4x4 because it will wreck things in pretty short order but you don't have 4x4.
I'm not totally clear what the issue is, but it's something to do with the front/rear binding.
If you aren't in 4x4 then spare on front is fine, or on back, but on back I think eventually it would wear out LSD, but obviously you can drive it some distance otherwise they wouldn't have put different sizes.
However, to mention, if you are in 4x4 chances are the tires can slip/drag (gravel, dirt, mud) so actually you can be in 4x4 with different tire sizes, just, don't drive on dry pavement in 4x4 like that.
Others know more....
When I asked my local Ford parts sales guy if I could get a new door jamb sticker, he told me yes, but Ford would have to fly someone out before a new one could be placed on order.
