1987 2wd 5 speed ford Ranger tk5 transmission shifter fell out of my transmission and idk where to find the part
Jerico
Oklahoma
My shifter in my truck that you use to shift with fell out of the thing that holds it in and I think the transmission is a Toyo Koygo 5 speed but I don't really know that much about it and my truck is a 5 speed 2wd 1987 2.9l Ford Ranger, so if anyone knows where to get the part or how to fix the part help and comment. I will post pictures tomorrow probably. And if anyone knows where to get a tk5 shifter kit let me know please. And if anyone knows how to fix the part or knows if another part will work with it let me know please. What transmissions can replace the tk5 transmission that's
in it.
Have you pulled the boot out of the way and looked at it?
I had a similar set-up once but don;t recall having that happen
Someone soon enough here will know something about it
I haven't done that yet but I will do it tomorrow and I will post pictures of it tomorrow
You found the right place to go with it, tho maybe not at the best time
It may be as simple as a bolt came loose that holds it
Yeah it could be that simple but to will need to try to fish it out of the transmission
Wait if you can until someone has more info. The only thing worse than doing nothing is doing something wrong in this instance
Broken TK shifters are a somewhat common occurance...i dont recall ever hearing of one coming totally out though..but i suppose it could happen under the right circumstances.
Unfourtantly no one makes the shifter anymore. So ebay/car-part.com/this place are about your only options for finding one
Well guess what?!
Last i looked this company said they were out of stock, and had been a while but..looks like they are back!
Well guess what?!
No it still says it's out of stock for me
Try emailing them. It didnt say that a few hours ago. It just came up for me to.
Coreshifters has a really expensive hurst one, but otherwise you're kinda in bad shape. I have one that's in pretty bad (but working) shape I pulled from my busted trans that I can ship your way if you really need it still.
Coreshifters has a really expensive hurst one, but otherwise you're kinda fucked. I have one that's in pretty bad (but working) shape I pulled from my busted trans that I can ship your way if you really need it still.
It's ok I might try to find the one rubber peace at the bottom of the transmission because it might be there
there is a wiper arm bushing kit dorman sells that has a white cup-shaped bushing in that works realy well. dorman number 49447
