Atlas transfer case info
Northidahotrailblazer
Truck of Month
Northern Idaho
8 inches
37"
Hey has anyone bought an atlas transfer case recently? I've been looking on bronco grave yard and even on the other sites its a little confusing. all of them look like there builder cases now? Idk, I just probably need to call and talk to them, but it just doesn't seem right, it seems like there prices have came down. Its looking like its going to be around $1700 bucks shipped. I don't know that just seems really cheap and something is off to me. Can you hook up your stock VSS to it also? that's something I don't remember you being able to do back in the day.
Technically, they've always have been builders due to several factors: input shaft splines, number of gear sets, left/right output. But 1700 is definitely on the buyer side.
I found this for the speedo...
8. Atlas T/C- Speedometer Options - Advance Adapters
Advance Adapters makes the Atlas - Bronco Graveyard does NOT. They are just a reseller.
There is no way you are going to buy one for $1700 unless it's used. The two speed ones are $3000+, four speed is $4000+. Go on the Advance Adapters website and use their Atlas builder configuration thing, that will show you all the parts you need and cost for each one.
Yeah $3K-4K sounds more right. Thats why bronco graveyard didn't seem right lol Ill try Advance adapters web site again. There web site must of been having issues when I tried the builder conf thing and it didn't work. Ill try again again.
Thank you! that has a lot of good info in it, ill do some reading up, Idk i was looking for something like that on advance adapters page but idk I could find it for some reason.
