- Aug 6, 2007
- State - Country
- GA - USA
- Vehicle
- Ford Ranger
- Total Drop
- few inches
- Tire Size
- ~30"
That kit may be different than the others I’ve used and what others have used. Meaning the head light lens might stay that way. The ones I’ve used were maybe good for a year unless you clear coated the lenses. Without a protective coating, they just haze over again.
Oh, I don't doubt that. I fully excpect it to haze up again, but this is still the best results I've had for the kits I've found at the local auto parts store. If it tides me over for 6 months to a year I'll be happy.
Ideally I'd remove the headlight, sand it to 600 or 800 grit, clear coat and buff. That takes time, place, and conditions that I don't have access to right now.
-AKA- I had an hour or two to work on it outside before it got too dark to see. I don't have a place inside to do it. If I had more time to work on it while the sun is up it's still too cool out to reliably spray paint right now.
Perhaps come spring or summer I might invest in doing that. I've actually got enough 500 and 800 grit discs left over from the kit that I'd only need to pick up some clearcoat and the stuff to buff it out.
The future of this truck is still a little fluid. I don't know if it's going to get sold, or get kept and fixed back up. If the latter I don't know if I'm going to keep it looking like a '99 or give it a face lift. I'll be replacing the headlamps if I facelift and I might still replace them if I don't.
