RustyDusty
Hey I've got a 1987 4x4 ranger with the 2.9 and a4ld auto transmission. It's due for some new tires soon and I'm considering adding a bit of lift to it along with some larger tires. I've read I should be able to fit 31" tires after a 2" lift but curious to hear what anyone here has to say about that. This is not a truck I'm trying to dump money into and it seems like the cheapest and safest way to add a little height would be some 2" front coil spacers and a 2" add-a-leaf kit for the rear. I've seen a kit that comes with everything necessary for just under $100. With only 2" of lift I should still be able to get a proper alignment and avoid getting any new parts like longer brake lines, shocks, drop arms etc.. I'm wondering if anyone could tell if my rear suspension is stock based on a photo. The leaf springs are already sitting on blocks and I want to confirm they're stock and that I won't run into any compatibility issues when I have my rear axle on the ground trying to throw a new leaf in the pack. This will be my first time adding a leaf. Thanks!
