2.9 turbo??
no hasnt been it has 1" of clearance i built a shield out of a 3" piece of pipe and temporarily wrapped it with foil so far its been great. you can see that in one of the pics above
im really thinking about it. i have a freind that has a turbo and piping for cheap. but the hardest thing would be converting it to mass air
'87 sucks more to convert over compared to an 88+, but look in the tech library for 'MAF Conversion'. It's has the wiring differences for either an 86 or 87 model already laid out. I just got the model specific diagrams and sorted it out on paper when I did mine. It's really not too hard. I think getting it running right is going to be the hard part. But that's just my opinion.
Pete
I converted mine to mass air. It was really easy.
Here's what I did electronics-wise:
Swapped in MAF computer
Added a stock MAF sensor from a 5.0L Mustang
Installed 24# injectors
That's it.
It ran like a champ and I had to do zero tuning. Probably would have run better had I had a way to tune it, but it saw 15lbs of boost everyday without any probs. (It was my DD) Fun fun truck.
I am not saying that the diagram on the site is gospel, but it looks like he is going to have to do a few minor wiring mods in order to keep the ability to pull codes.
See: C. EXAMPLE OF A PIN OUT COMPARISON BY NUMBER BETWEEN AN '86/'87 SPEED DENSITY SYSTEM '90 MAF SYSTEM
http://therangerstation.com/tech_library/MAF_Conversion.html
He still needs the pins and the plug for the MAS, consider hitting the junk yard for the MAS pins, wiring and plug for the MAS from a early 90's Stang or similar. (You might need to get the entire harness, it takes a while to dig it out) I used off a '93 HO harness. Ford Dealership part dept will need to see example pins (be prepared), or I believe they can be purchased from Ebay.
And it's strange that the 2.9L ran fine with the 24# injectors. I ran into problems with 19s at idle. I used an IST Air Adjust that's mentioned on that page to somewhat compensate for it. Maybe it was just the MAS I used? It was from a 3.8L Taurus, but I also tried a 65mm MAS from a Stang with similar results. I ended up just giving the Stang MAS to a friend of mine that was trying to diagonse a problem.
Pete
I meant I followed Bob Marr's MAF conversion write up. It was really easy. I think I used an IST MAF harness to do mine.
Beats me why it ran fine, but it did. I drive it to work every day for a year and a half or so. The Ford computer did a superb job of compensating for my lack of EFI knowledge at the time. LOL It was probably a tad rich at times, but drive-ibility never suffered and it idled like normal.
I got to stop talking about it or the next thing you know I'll have another Ranger in a kazillion pieces in my shop with me wondering "how'd I get here?".
It was really easy.
Yes, it definitely is a strait forward swap. I am going to try and sell my old MAF computer & other stuff once my 5.0L is in, hopefully someone would make use of it.. But I'm guessing it won't be going until next spring, I need more money, but I am close to having the motor done.
Hahaha, you probably wouldn't be saying that once the 460 project is going. You're freaking nuts, I can't wait to see what that thing will dish out. :icon_thumby:
Pete
there are other options like converting to stand alones like megasquirt and or stay speed density and get a dyno tune. Im not 100% on the 2.9s engime managment but im sure theres some things that can be done
Upcoming TRS Events
Featured Ranger Based Vehicle
