Needing help with my 2000 ford ranger 2.5l auto transmission!
PROBLEM SOLVED: PURCHASED REBUILT VALVE BODY AND IS WORKING GREAT!
Miles on Vehicle? Miles on Transmission?...transmission works fine when it is cold
...2.5L auto transmission...4r44e
...hot it starts slipping, hard shifting
...has reverse
...valve body problem?
INSTALLED REBUILT VALVE BODY, SOLVED ALL THE PROBLEMS! PURCHASED ON EBAY FOR $135It could be...
There were some valve body gasket issues... but I think those would cause issues all the time and not temp related.
Let's see if someone else chimes in with something more helpful.
It could be...
INSTALLED A REBUILT VALVE BODY I PURCHASED FROM EBAY FOR $135, PROBLEM SOLVED! THANKS!Here's that 2010 TechServiceBull mentioned above
& this forums tutorial page
Ford 4R44E / 4R55E Bad Separator Plate And Valve Body Gasket
www.therangerstation.com
TransGo or Sonnax may have equivalent kits available.
IT WAS THE VALVE BODY! I PURCHASED A REBUILT ONE ON EBAY FOR $135, RUNNING AND SHIFTING GREAT! THANKS!It could be...
INSTALLED REBUILT VALVE BODY FROM EBAY FOR $135, RUNNING AND SHIFTING GREAT SO FAR! THANKS!Miles on Vehicle? Miles on Transmission?
ATF Level+Color+Smell? How long since ATF+Filter Change & Band Adjust?
TechServiceBulletin 2010\Earlier for ValveBody Kit+BondedGasket repair in this era 4r\5r Trans; has this been done?
I INSTALLED A REBUILT VALVE BODY AND THE TRUCK IS RUNNING GREAT! PURCHASE WAS ON EBAY AT $135! THANKS!Here's that 2010 TechServiceBull mentioned above
INSTALLED REBUILT VALVE BODY AND TRUCK IS RUNNING FINE! THANKS!Miles on Vehicle? Miles on Transmission?
INSTALLED REBUILT VALVE BODY AND ITS RUNNING GREAT! $135 ON EBAY!All Automatics run on Fluid Pressure
Pressure is supplied by the pump inside transmission hooked directly to torque converter, so spins at engine RPMs
The Valve body routes this fluid pressure to the Clutches and Bands(brakes)
The pressure holds clutches engaged or disengaged, and brakes(bands) on or off, this is how the different ratios(gears) are selected
There are pressure ports on the outside of transmissions to test pressures in various "gears"
Obviously internal fluid leaks will lower pressure, sometimes overall and sometimes just for one valve, and valve seals can leak
These leaks usually occur in the Valve Body
The 4R44E or 55E were first used in 1995 Rangers, the 5R44E or 55E are THE SAME transmission internally, so any info on either applies to all
Good article to read here: https://atracom.blob.core.windows.net/gears/2003/2003-05/2003_5_50.pdf
Explains what is happening inside as ratios change, what valves are used and not used
Also explains why answering "why is trans slipping" is not easy or specific, there are multiple reasons/causes and they overlap
Wholesale changing of Valve Body "may" fix it
But not a waste of money because if it doesn't fix it then you need a rebuild and already have the new valve body for that![]()
INSTALLED REBUILT VALVE BODY AND IS RUNNING FINE!Miles on Vehicle? Miles on Transmission?
