What is the logic module and why is it needed?
I would think that you just draw the power from the stop light circuit and be done with it.
It would be needed if you tap into the taillights because if you didn’t, the third brake light would come on with the parking/running lights.
I tapped into the third brake light circuit in the cab and ran a wire back for both mine and dad’s. Also ran a 12 volt hot and a ground back there so I have a light inside the cap.
The logic module is used when you take two signal circuits (both left and right turn) that are also used for brake lights and need to use it for a third brake light. Without it... third brake light would not work properly. Not sure it has anything to do with park lights.
Got it pulled out of the swamp and have it at home finally! No pictures of the extraction itself, I drove my ford 2000 tractor there with the flatbed, backed the trailer as close to the truck as I dared & offloaded everything from the ranger onto the flatbed, The less weight the better. Next I moved the trailer out of the way & unhooked it. Took out my yellow tow straps (2) connected them then put my pintle hook into the hitch receiver. connected everything then backed the tractor to hook up. Used a clevis on a 3-point drawbar with swaybars, raised just enough so Im pulling “up” on the ranger and likewise “down” on the back of the tractor. Had about 40’ total strap from ranger to the tractor. Was outside the tree area just enough to where it wasnt swampy wet, just soft enough for the tractor to get a good bite. Put tractor in 1st, 1/4 throttle & it pulled it right out. I did have to stop part way & remove a strap then pull the other way along the ditch. Bren came along to be steering control in the ranger & also drive it home rather than load everything back in the truck, put tractor on the trailer then drive home towing with the ranger. Stone & mulch is still on the trailer now, Ive moved that around enough. Ants were trying to set up house in the door weatherstripping no longer than the truck had been sitting. A few more days would of been worse. Probably the worst of it all was pulling out on the road to leave & having all the mud fling everywhere. That & putting all the gear away, brought more than I needed but wasnt sure what would be needed. Had 3 log chains in addition to my 2 tow straps, a cable come-along, a boat winch with a pully, two sets of ramps, one wood & one aluminum. A shovel, floor jack, many 2x4’s and duct tape. yes duct tape. (hate it when log chain hooks come unhooked, so I tape em!) Was going to back up to truck, raise it with the 3-point & put ramps underneath but decided against it, didnt want to chance sticking the tractor and I figured making the butt end of the ranger weigh less would be my best bet. Ive yet to put the tailgate back on or wash it. Maybe tomorrow.
View attachment 77069View attachment 77070View attachment 77071View attachment 77072
Told ya the tractor wouldn't play fair. :icon_thumby:
Offloading what I had in the bed was a big help too I figure. Later that day I did the math on what was in the bed and it was nearly 800 pounds. Finally know why the ford tractor has such bad “death wobble “ at road speed- steering box wear. Its manual steering and if I put my feet on the ball joints of the arms coming off the steering box and apply pressure the death wobble stops! Good to have 2 vehicles again, hopefully the escape comes back home this week, not looking forward to that bill for services but it was needed and better left to someone who does that kind of stuff on a daily basis.
I found a step side camper
Yup. A leer but the only bad thing is it's dark blue or black, not red. Oh well, can't be picky with a step side
Got home from camping/wheeling today, took the '90 and a 4 wheeler, went with two other families, glad I brought everything I did... Sunday it hauled one friends quad back to camp once he noticed the rear swing arm was cracked in like 3 places... got back to camp then took it apart and used my welder to get it back going in a couple hours... then sitting at camp some guy came up and asked whos Ford that was and if he had a strap... turns out his dune buggy had hit something while doing a wheelie and broke the oil pan... so I drug it to camp, then later out on a ride (yes, I was riding a Ranger while another like 6 people were on quads... wife didn't want to ride a quad...) which was convenient because one of the kids had their rear carrier bearing in the swing arm explode as far away from camp as possible... so I drug that back to camp :)
They used to call the Ranger Tumble weed since around 11 years ago I rolled it, now they're thinking of calling it the rescue ranger... whatever, it's all part of the experience :)
On Saturday the weather was complete garbage but there was a poker run in the dunes which is a good time, bunch of raffle prizes, and it was kinda fun trying to keep up with quads :), Ranger did good, still has all the front tire clearance problems, the upper balljoint adjusters moved in like they always do so the camber and toe is way out but that doesn't matter offroad, it's been aired down since March... After 12 years the Centerforce clutch is starting to do some surgy stuff in low range low gears... The main problem with it was at one point the stereo quit working... conveniently it fixed itself on Sunday? it's only like 11 years old, I don't know what it's problem is... lol
Is it one with windows on the angled part or solid fiberglass? It seems to me the solid side one would leave a huge blind spot but I’ve never been in a step side, let alone one with a cap.
its the solid one. thats the only thing that bothers me about having one of those on is the blind spots. i have had them on other trucks with straight beds and i always feel like i cannot see alot of the areas behind me.
but i am hoping the benefit of having it will out weigh the blinds spots. my oldest son thinks it will be awesome though
It’s possible to get used to living with larger blind spots. My F-150 has ladder racks and side boxes and I drove a dump truck on a regular basis for about 8 years. I have been kicking around the idea of getting one of those 360* camera systems and fitting it on the truck just because I don’t trust people, but I’m used to dealing with it
My issue has been more due to the tint at night. It makes it hard to see what I’m backing into. With the window layout on my cap, there little to any blind spots otherwise.
Eventually, I’ll get some auxiliary back up lights so that the tint issue is minimized or eliminated.
Tried adjusting the steering box in my F-150. I was a little worried about trying that because I did it once before and I want to say it had started binding and I backed it off a little. Seems ok this time, but I really had to crank it in, think I put 5 or 6 turns on it before the wheel felt ok. I moved it back and forth and it doesn’t seem to bind, but I’ll have to drive it. Still think I’m gonna have to replace it.
That said, I did find a spare steering box that I had. Looks either nearly new or refurbished, but it doesn’t seem to want to turn by hand. Not sure if it should be that tight or if something is wrong with it.
Sharpened the chain on my little Stihl MS-170 and got it cutting straight again. Think the carb needs adjusted yet, but it works. Tested it out on a couple hickory chunks.
Tried tinkering with the green Ranger, but didn’t really make much progress
Found a driveshaft. Called this morning about closest one I was looking at on the car-part website, $50 and an hour away. Truck had already been crushed. Next closest one was about twice as far and twice as much, but the place was sketch. (so they probably would have had it) Only ones the first yard could find one at was 4-5 hours away. I'd seen their lsiting on the car-part website. Showing new parts at $600 plus.
Remembered I had a extended cab reiveshaft at my parents house, too long but right ends. Looked for a place to get it shortened and struck out.
Taking a break from everything I hopped on facebook and top market place listing was for "Ford Ranger Parts". A guy about 10 miles from where I live was parting out a 1990 and 1993 Ranger. The '90 just happened to be a long bed with the exact driveshaft I needed. Offered $30 and I'd pull it myself, bed was off so easy job. He agreed! 45 minutes later I had a driveshaft in the back of the truck. Took 30 minutes just to find my 12pt 12mm tools. I really need to clean/organize shop next.
Also discovered that the rear axle in the little things is a 3.45, not the 4.10 like the door tag led me to believe. Not sure if the axle has been swapped or F75 is an elusive axlecode not in the chart. I assumed that just the F7 mattered which meant 4.10. Truck also has what appears to be a BII sway bar already installed in the rear, I had one I was planing to install, as well as an aftermarket Walker Quiet-Flow exhaust installed. Now I've got to figure out if I'm reinstalling the currently removed (via sawzall) catalytic converter how I'm moving forward with the rear axle swap.
