Dust shields for the 2011's front brakes just came in. I know what I'm doing today now.
EDIT: Slight change in plans. I'm going to need to prime and paint these before I install them.
Nowadays Eastwood makes a real nice epoxy based 2K paint, ceramic spray, and clearcoat which will hold up much better than conventional solvent based evaporative paints from rattle cans. https://www.eastwood.com/ew-2k-ceramic-aerosol-chassis-black-satin.html
@Uncle Gump I had to replace the retaining bolts that hold the dust shield in place. The threads are M6X1.00. The original bolt heads were 8mm but were so rusted I had to use a 5/16" for 5 of them and an easy out on the 6th. The hardware store didn't have any flange bolts that were short enough. So I had to use regular bolts with a 10mm head. They fit just fine.
I kinda figured that could be an issue. Mine looked sketchy last time i dud a wheel bearing. Damn rust...
I bought a pair from my local dealer last week, arrived in 2 days. price was slightly higher than Tasca.
they appear to be galvanized.
That should be good for 5 extra horsepower .
I had already removed the starter ring to reverse it, putting the worn teeth in a different spot. since I had the blaster out to do some coolant tubing I just threw the flywheel into the cabinet to clean it up.
us 'ol farts do stuff like that.
Went to some area yard sales today, started out in the escape but went back for the ranger, Got a upright cambell-hausefield compressor, 5 hp/26 gallon for $25. It needs some help but if nothing else the tank is worth that much. Picked up a heavy iron yard roller for $50 in the next town, made from a old 38” wide conveyor belt drum & angle iron frame. not “water fillable” but has a frame above roller that will fit cinder blocks (or tractor weights). not that it needs to weigh more, me & another guy could barely lift it on to the tailgate. Got a few other small things as well, certainly couldnt of done it with the escape. Unloading was easier, backed up into the yard towards the ditch, tailgate was 2” from the ground once I backed up as much as possible. Walked right out when it was empty too.
These ones definitely weren't galvanized.
Unloaded the 4 wheeler from the back of the '90 finally... then moved it out of the shop, got tired of the drivers door sticking after I put PEX on the door pin so I took a file to the PEX and went until it reached the level of the indents, MUCH better. Next step will be to work on the "auto lock" feature, I disabled that feature for last weekend with some electrical tape around the lock lever deal through the door panel... maybe next weekend...
Since I just got power to a panel in my shop last Tuesday I finally went to town tonight to get some supplies to wire some things in, holy cow... $56 for a GFI breaker, glad I don't have to buy wire (bought a spool of romex for $60 before prices went up, just saw the same spool for like $160... and got a spool of MC for much less than the $200 it is now...). I "think" I can get away with jus wiring stuff with Romex, I'm hoping anyway...
It's been more of an almost every day project for the last 3 weeks, but I built a new flatbed after over 10 years of contemplating how to make my old one better, it's about 99% done now, so pictures as previously promised. I wanted the ability to have some over the cab storage, to be able to move the spare tire to any location on the bed, and the ability to be able to replace boards without needing to play guess where the old holes in the crossmembers are. If anyone would like more info, i'll do my best at a build post on it.
I opened my new ignition cylinder and played with it. Then I read the protective sleeve telling me not to turn it before installation. Hopefully I didn’t ruin everything
The 4.0 swap is "done" enough to get a celebratory float today.
I went to lowes for 2- 16’ 2x4’s. Shoulda took the flatbed, thats a lot of board hanging out the bed of the truck!
Other than the canoe and kayak, that is one of the reasons I have roof racks. I have 17' before I have to start worrying about over hang.
