lil_Blue_Ford
Cut & Weld
⭐Supporting Member
💻 TRS Socials
TRS 25th Anniversary
- Aug 6, 2007
- Butler
- State - Country
- PA - USA
- Vehicle
- Ford Ranger
- Total Drop
- 4”
So I finally spent some time working on the green Ranger project. Tried extracting the one last broken bolt from the block, had to use a pipe wrench on it to get enough grip and it was slowly coming and then a couple teeth broke off the quality Chinese 8” pipe wrench. Got mad an pulled out my Rigid 12” pipe wrench and it promptly twisted off the end that I had been working on. Then I couldn’t get a good re-set bite because the china wrench mangled things. Knew I shouldn’t have bought it, but it was the first time I’ve ever come across an 8” for sale and I’m always borrowing dad’s 8” that he’s had forever when I need leverage and bite on a broken bolt or rounded nut and nothing else is working. Guess I’ll have to weld a nut on or something now.
So then I pulled the brand new timing chain cover out of the box (Allstar Performance). It was made in Mexico and looked like it was machined by a blind guy. Absolutely terrible quality. Well, maybe China made would be worse. Maybe. I cleaned off the flash from the mold when they cast it, chased the threads (since new bolts didn’t want to thread down in) cleaned up a couple scratches and distortions to the gasket surfaces, spent a bunch of time fixing the coolant passages (it was like there was a terrible fit between the mold halves and someone just shoved a piece of rebar through the hole to open it), and put the new crank seal in. Sadly, that’s about as far as I managed to get today.
