sgtsandman
Aircraft Fuel Tank Diver
⭐Supporting Member
TRS 25th Anniversary
 - Mar 11, 2017
 - Aliquippa
- State - Country
 - PA - USA
- Vehicle
 - Ford Ranger
- Drive
 - 4WD
 - 2.3 EcoBoost
- Tire Size
 - 265/70R17
- My credo
 - Anything that can go wrong, will go wrong. Plan for it as best you can.
Last night I finally replaced my spark plugs and wires on my 98 2.5L. Haven't changed them before and the #3 wire boot on the passenger side was partially melted and visibly arcing/ticking while running.
Boy, that was not fun. I had the wobble extensions, etc. so the actual plug removal and install was the easy part. One of those flex cable claw grabber tools actually worked great to feed the plug down to the socket and get it started. Getting the wire boots off #3 and #4 on the driver side sucked. I didn't have a long enough pliers and they didn't have the plastic handle covers on them. When I finally got #3 boot off, the metal inside of the plug boot stayed on the plug so I couldn't get my deep socket on it so I had a heck of a time with that. Then #4 did the same thing. Luckily, my wife doesn't mind working on cars and has small hands and came out to help.
Snaking the new wires and boots with the plastic puller handles on them was another pain for #3 and #4. It was almost impossible to get them turned into position and lined up properly. I'm still not sure I got them pushed back on all the way.
Anyway, I was up til 1am and this morning I ordered a set of 11" long reach needle and ring nose pliers, lol.
Those driver's side plugs are a real bear for sure. Been there. I think the 2.3 engines are the same deal, at least the dual plug versions.
