- Jan 9, 2022
- Fort Worth
- 4.0 V6
- Total Lift
- 0
- Total Drop
- 0
- Tire Size
- 225/60/15
- My credo
- ODAAT
My 1990 Ranger was having hard starting problems since I got it, I would switch key on/off like 5-6 times for it to start. Replaced known problem area parts ie fuel regulator etc but no luck under hood trying to solve problem. Stating to think fuel pump was bad, but I could hear it when switch was on. Came across this Redline fuel cleaner by chance searching for PEA chemical cleaner for fuel systems, Redline makes one of the best fuel system cleaners I have ever used. If you have a high mileage truck I would say do this towards the end of you oil life as you will need to change it!!! I ran 1 bottle of Redline with full tank of fuel and noticed immediate results with idle and starting problems on my 2.9L. I now do not have a starting problem, fires first try every time!! Truck is far from perfect but I'm still amazed that I didn't know this was available in this strength. Im not kidding about changing your oil after using this stuff, my oil was black from carbon build up, I only had Redline fuel cleaner in for one tank. Amazing results!!!! Q
