4 Codes After Head Rebuild
MankDeems3.0
Fargo ND
Alrighty, found my blown fuse in my charging system. now that I can connect to OBDII I have 4 Trouble codes after rebuilding my heads.
P0112 IAT Sen 1 Circuit Low
p0113 IAT Sens 1 Circuit High
P0123 Throttle/pedal c Pos Sens/Switch A Circuit High
P1121 Throttle Pos Sens A Inconsistent With MAF
My initial inclination was my pigtails are backwards but the TPS and IAT are not interchangeable. anyone have any ideas? Truck runs really bad but the rotating assy sounds fine. I've attached my trouble codes below.
Unplug both IAT and TPS
Reset computer/clear codes
Restart engine
See what codes come up
Should be
P0109 Intake Air Temperature Circuit Malfunction
P0120 Throttle/Petal Position Sensor/Switch A Circuit Malfunction
You are testing if there is a short in the wires to these sensors
Ignore
Its only there because of the TPS code
Both IAT and TPS share 5v power from computer, so does ECT sensor and MAF but no ECT sensor or MAF codes so "we" can assume both sensor are getting a good reference voltage
But you can test the grey/red wires at each sensor with key on engine off to make sure
Test to battery Negative and ALSO battery positive, its a pull down circuit so can appear as a ground, not 5v but you should see the 5v difference as a +/- 5v
Restart engine
Should be
Ignore
Will test in the AM and see what codes come up. I work at a dealership but diag is still not cheap. What would be the next avenue if there isn't a short in the wire?
