Junk Collector
⭐Supporting Member
Truck of Month
One of my buddies has been wheeling an early Bronco since the early 90's if not earlier...said he had the same issue with the C bushings. They are fine for road and mild wheeling but when you cycle the suspension to both ends of its travel many times and they just fail quick. He and I both welded little strips of metal to the sides of the caps and radius arms to keep the bushings contained, that helped a lot but just delays the inevitable.
