'85 Ranger Restomod
Well for $4.90 + shipping I have a plan b...
It only took like 6mo but I got my Jerry can mount put on.
It needs a little tweaking (I didn't have any lock nuts on hand) and I kinda don't think I like the strap but otherwise I do like how it looks.
Now if it would just warm up so I can repaint the can.
Anyway, various wheels have been turning on various side quests of late.
The dizzy exhaust situation with my front driveshaft, needs something complicated and I might have found something that will work.
Basically rob the kinky drivers side pipe from a 90's V8 Dakota/Durango.
And then project #2... the winch I am starting to catch heat for over storing in the dining room.
I whipped up a prototype on my 2D rapid prototype machine and have been doing a little poking around for getting it mounted behind the bumper.
Considering I can trim the bumper if needed and if I just bolt the winch plate on the bottom of the frame... I could shim it down a little if needed (I kind of like incorporating angle iron wrapped around the frame to reinforce the it anyway).... I think it might work
I need to pull the grille guard/bumper off and play with it with the plate and the winch to know for sure. The lever for the winch is a concern too, I was hoping it went ahead but it looks like it goes back.
I was hoping to go with the accessory style winch mount but I have qualms with my bumper relocation brackets holding up. So maybe go stealth mount and wait for a much more common factory grille guard to pass by? Also keeping it closer to the axle to to help the CG would be nice too.
Your above comment about a grill guard, I saw this one today in the scrap yard.. not sure if it's of interest to you?
Bye the way cooler is sweet.
Bye the way cooler is sweet. View attachment 71703
Nice, but I think I will pass for now. I do have the one I made in high school for the moment.
I wouldn't mind sneaking up on the regular Ford grille guard like what the STX's got at some point though.
I will keep eyes open. As always for unique accessories etc. like that console last weekend just couldn’t pass up. Hopefully someone can use it.
You know you could almost make that with a bender and cnc machine
It wouldn't take much to laser out the plates.
A couple guys on here have benders.
The thought has crossed my mind...
The brush guard kit is a seperate kit from the grille guard kit so it is possible to sneak up on a pair loose too.
make a couple of them and sell a few to recoup some money
Kinkless benders are relatively affordable last time I checked.. 3-400$.
It IS a ton of money.. but.. considering all the cool stuff you can make with one it's worth it.
At this point I would rather have a wire welder...
What do you run now for a welder? Stick?
Buying tools is like doing mods to the motor in a way.. The supporting tools needed always bring the total cost way up lol.
Yeah, stick.
I think I would trip over a bender in my tiny garage more than I would use it.
