External Hard drive disappears
Ranger850
Doesn't get Sarcasm . . .
Tallahassee Florida
Stock 2"
Stock
I have an External Hard rive that keeps disappearing from my computer. I van un plug it, the plug it in and the computer will see it for about 3-4 minutes, then it disappears and the computer cant read it. It is a "WD" My Book Essential 1TB hard drive. I have another one, 500G, it is older and works just fine. Does anyone have any knowledge of where I should start? Cables seem to be fine. I switched them out, and the problem is with the "box" not the cables.
pic of cables.
65557
link to what I actually have.
what os you running? and can you go to properties and assign a drive letter to it?
Running on macOS High Sierra. I'm new to the apple world and may need things explained to me. I will try to assign a drive letter and get back soon. Thanks @Angie
Sorry Don't Know if it matters but the Ext. HD is 2TB
Is someone stealing it?
i can't help you. I know nothing to do with MAC or apple. sorry. good luck with it.
well that went south quick
Are these externals based around 3.5" desktop hard drives (external power supply) or 2.5" drives that are powered directly from the USB cable?
They have an external power supply
Have you tried swapping the power supplies between them?
That seems to have worked, without causing the 500G HD to "disappear". I hope 1 of the 1,000 old power cords I have at home will work, because I have to use both EHDs simultaneously
I spoke too soon. it's gone again. 500G still visible. :icon_confused: It still has the LED lit, it's getting power and it even shows up on the side bar. If i do nothing, it stays there, when I use the computer, it disappears after a few minutes.
The thing is, with this computer, you get a warning if you don't "eject" the device before you unplug it from the USB port OR the power supply. I'm not getting that, just all of a sudden, it's not there
