If I remember correctly, Expo springs will increase the load capacity to 500lbs or increase it by 500lbs. I forget which, now. But they increase the ride height by around an inch and a half.
I’ve built my own leaf packs before, one of the keys is to keep the leafs as long as possible if you want a better ride, lots of short leafs carry a lot of weight without sag, but it will ride like the axle is welded to the frame. Granted, too many leafs of any length will ride hard, but longer leafs allow more flex. My first Ranger I rebuilt the packs by cutting the eyes off a set of mains and putting it between the main and the first leaf in the standard pack. I also added another leaf in. Made my 2wd sit like a 4x4 with no blocks, rode decent and didn’t care what went in the bed.
My F-150 I got some F-250 packs and did much the same thing plus put 1 ton rated coils in the front (progressive rate and coil over helper shocks). Rides a little hard but I can put one ton in the bed and it doesn’t look like I have anything on the truck, sits near factory height at that point. Takes about a ton and a half or so before it starts looking like I have weight on it. Which is exactly how I wanted it, it’s been my hauler for quite a few years now. It sits empty like a 250 or lifted 150.
My choptop I did the same kind of thing but because of how light it is, it rides harder than I’d like. At some point I’ll do something different. I used Explorer packs to build that by adding two extra leafs. With a shackle it got me about 5” of lift over factory
I had some front ebrake cable stretch, so I needed to shorten it. Dorman makes a cable shortener but it's fugly.
I rooted around in the junk bin and came up with this.. The nuts are locktited.
Not as ugly as the Dorman. I'll keep it Fluid Filmed.
-Jazzer
Not loaded up up like yesterday but worked it still.
Ended up hauling off 7 loads of brush from the bosses property. I think its time to invest in a bigger little trailer. Maybe a 6x10 or 6x12. This little 5x7 tilt is handy but sucks for this kind of work.
So FedEx showed up this morning with transmission parts. So I popped the valve body off and got to work. Been trying to video as much as possible but it’s been hard because I’m not really set up to video my work. So it’s taking longer than it should because I’m trying to document the work as much as possible. Got probably 2/3 of the valve body done. Also had a delay because I was set up outside and was getting to work on it then started hearing thunder and it started sprinkling so I packed it all up and relocated to dad’s wood shop, which was a less than convenient arrangement. Of course, it never actually rained here, but I’m betting it would have if I wouldn’t have relocated.
Fiberglass spring? I was not aware there was such a thing. Mine has the 3 spring pack but they’re so worn out the section in front of the axle actually has some negative arch. The only reason the ride height is so high is because it has 2.5” blocks in the rear. I bought it that way and for $400 im not complaining to bad lol. Thats an interesting setup though, if i needed something to keep the axle wrap under control i would probably just build a set of slappers.
Yeah, fiberglass leafs have been around for a while. The first ones I heard of were in Corvettes. They even put them in sideways to boot.
I also had a ‘87 chevy astro van that used a single fiberglass leaf (per side) on its rear suspension.
Finally got the red red ranger back together and brought it home.
Forgot to plug in one of the of sensors, now thr plug is melted, there is an exhaust leak for sure. The dinger goes ding all the time regardless of if the key is in or not, so I broke something for sure.
Changed the oil. Went with Pennzoil semi synthetic this time.
Seat cover is on, steering, ball joints and rear springs are greased. Also checked fluids on the axles, tcase and trans.
