I returned some valves one time and didnt have a problem... things like direct fit cats technically dont exist unless its from the dealer and they still require modification... I work at a small auto repair shop and someone cut 15 cats(some were just resonators lol) and like 80% required cutting and welding. If you can knock the studs out just buy some nuts and bolts and make it work!
95% of the ladies and gents at various local Autozones and Advance Auto Parts I regularly visit are quite helpful, pretty knowledgeable, and willing to do extra research to make sure ive got the right parts lined up, bring them from nearby locations, call me to let me know they’ve arrived, etc.
All we want from Rock Auto is a single access point for asking parts questions. Even just an email address that doesn’t have to be scoured up from forums.
In any case, I contacted them via Facebook message and they gave me the email for service (same as someone posted above) and I had one email exchange and they provided a shipping label for exchange.
They didn’t reply with any responses to my specific questions though, just offered an exchange.
I’m still left with doubt that the studs will work with any nuts, and also a fitment issue just mentioned here...
I've had good luck cleaning engines by adding one less quart of oil and using ATF (Dexron/Mercon) for the last quart. Usually washes chunks out the drain plug. Will stop up a filter if you leave it too long tho. I drive it around 100 miles with the ATF in it.
www.therangerstation.com
I am in the awkward scenario of possibly ending up requesting a second return, even if the part isn’t faulty, since I’m unsure if the catalytic can even be hooked up to a 1989 as advertised by rock auto. I got some serious attitude from BRExhaust about this too, saying that rock auto is to blame and then suggesting I order more BRExhaust parts to fit downstream from cat, which I did and only found when receiving it that their pipe doesn’t fit their own cat either.
So who’s to blame? And who will take any responsibility?
more details about fitment in that thread if anyone is interested.
Yeah I agree and I would love to do that and of generally that mentality. But then that’s a 100% commitment to the part and surely they won’t take a return or exchange on it, and at the moment I’m not even convinced this cat can be connected to this truck so it’s best I do this the formal ways.
here’s the input of my Intermediary Pipe, made by Walker which I put in last fall and which looked the same as what I took off..
obviously those two ends above mate up perfectly with the flat gasket as illustrated here..
But, the BRExhaust I bought from rock auto has this kind of output(I forgot to take a pic of the actual exhaust but this is exactly what it looks like..)
sadly the other end isn’t pictured on website or this wouldn’t have happened because I would have seen it.
but I found this diagram that shows it’s system..
so, I think the easiest solution is to see if this intermediary pipe will work for my truck since it clearly is designed to mate with the new catalytic, but my concerns are about fitment / hanging downstream..
I usually just drive to the reputable exhaust shop...
One of the few things I typically pay to have done. My time and aggravation is worth the price of admission most times. I drop it off... I pick it up done with a warranty.
If I still had a hoist I would certainly do more. But I will most likely lay on my back and do a Gibson cat back in the foreseeable future.
I had a bad spot right after the first resonator on the escape. ( it has many ) had a local shop remove it and weld in a pipe to replace it. $50 well spent and only a 30 min wait. I had to do the same thing on the hhr a while back, using clamps, adapters and such, took me 2 hours. If I had a lift maybe it would be different but I forsee myself “hiring out” exhaust work from now on. Im all for doing things myself, but when Its that cheap & quick to have it done and save myself the time, sweat & aggrevation-why not?
I think i may need to just make due with what Rock Auto sends me next. 500 bucks for a CARB compliant cat just isn't possible when having a shop do it. They'd likely have a 800-1000 tab just for the part itself. I made a decision to spend a couple extra hundred to prioritize the cat to be at california standards, since i'm here guzzling gas. My cats were already bored out by previous owner so the truck is pure exhaust and the cat needed to be replaced. So it's either Fed or Carb. But other than that somewhat lofty expense of going Carb, I'm still doing all the leg work in order to save total cost. I just removed an exhaust manifold incrementally by way of a sawzall, and any shop would have turned the project down or quoted me so much that I would have had to ditch the truck. Working on the pipes end feels pretty easy now.
I will order the intermediary pipe for 90-92, which has the correct connection to output of cats, and hope to just get lucky that it lines up decently enough with the muffler and tailpipe. I can create hang points if needed, and don't care too much if output of tailpipe is off from OEM by some inches.
But yeah, it's inevitable a welder is on the horizon.
For
a small yearly donation, you can support this forum and receive a 'Supporting
Member' banner, or become a 'Supporting Vendor' and promote your products here.
Click the banner to find out how.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
