Ok.... Do it the hard way.
If you think ford EFI is the easy way vs a holley sniper system you sir are drunk.
I put the holley on my 65 mustang in less than 4 hours and don't need to buy more computers to tune it. The system is idiot proof, the controls are are easy, and you have full access to everything without fighting with it. Wanna change parameters, just click some buttons. I don't see how in any way that it's "the hard way".
Try to tell a ford ecm you added boost... Or you disabled the egr.... Or say hello... You got better luck getting HAL9000 to open the doors.
Try to tell a ford ecm you added boost... Or you disabled the egr.... Or literally did ANYTHING.
The Explorer front accessory set up, the exhaust manifolds that fit the chassis, the best trans ever installed in a RBV... it’s practically a bolt in swap. I wasn’t talking about the fuel system.
I don't need any accessories but an alternator. And the best trans ever bolted to a 302 is the 4 speed toploader. I plan to find the same, or a Muncie rock crusher for the ranger. I have a toploader in the mustang so I know them in and out but the rock crusher is a temptation.
What’s your plan for power steering? That chassis never came with a manual rack. Are you just going to loop the pressure and return hoses together?
Took out the radio a few weeks back. Just getting around to building a box to make it into a cubby. It will be so nice to have a place to put my phone and wallet with out fighting with the arm rest every time. 🙂
Water pump to radiator clearance... All around very hard to beat the Explorer belt drive. If the 302 is older 28oz you can easily make it work.
I unloaded the 350X out of the back of the Ranger tonight, it was raining so I wasn't in the mood to get a ramp out so I cheated and used the A frame gantry crane and just lifted the thing, then rolled the Ranger forward by hand (level floors are nice) and set it down... Then I pulled the F350 into the shop in the Ranger's place and started doing rear brakes... got almost done with one side... Before I started that I saw the rear part of the headliner creeping down and since I caught a mouse in there the other day I thought it might be a nest so I ripped apart a bunch of stuff to get up there and it turns out it's just old and sagging... it probably doesn't help that something's apparently leaking in the back there like the third brake light... After I get the rear brakes done I'll start ripping into the engine, I need to reseal the oil cooler and start pulling the turbo for it's replacement, I have a feeling the EBPV actuator is leaking since that's apparently common, it's already bypassed so it might as well be removed while I'm in there... I'm hoping the turbo is most of the problem with power, I'll at least start there...
Pinto rack.
Throughout the week I covered every inch of cab floor and rear I could with sound deadening and cleaned the seats ALOT, new carpet came Friday, installed today. Also picked up a set of cheapo wallyworld seat covers. Sound deadening IS NOT FUN to install. But overall I'm pleased, looks better, smells better. And I found 2 more coin pesos. Test drive tomorrow after I button up trim
That looks fantastic!
I replaced the burned out dome light bulb and worn out brake pedal pad.
@2drxploder
Wow, looks great! I was going to take the doner 93 carpet, clean it and make it work in the 97 Ranger Rig, but I’ll rethink that now. Good job!!
Pinto rack.
We have an old mustang 2 behind my dads. I think its similar to the pinto. You could probably have. He may make you take the whole car though haha. It's been hammered in the rear. So a tow bill may be more expensive than it would be worth.
Installed intermittent/delay wipers in the 87 V8 truck today, then cut and hauled half a load of wood to a buddies shop.
