dcpppf
1988 2.9l 4x4 manual.
I recently did the plugs, wires, dizzy cap/rotor, and ignition coil... But I don't think any of that is the culprit.
So a couple of months back I swapped the auto trans with a mitsubishi manual. During this I put in a 4.0 clutch, fw, and starter. After driving the truck a month or month and a half I noticed it needing to start to crank a bit slower and felt like it was struggling to start a bit. Fast forward I do the plugs coil and dizzy with no change. That whole time I'm driving it every other day or so... Well I let it sit about a week and a half and went to start it last Friday and nothing.
So far I've tried charging battery as well as jumping it (I would have put money on a battery as this one is old)... Today I decided to check the ignition coil output and I got no spark in my tester. The coil resistances look good (under an ohm on one coil and north of 7k ohms on the other). It is getting a constant 12v on one terminal and the other dances on my dmm when cranking. I dont have a good tester yet to see if the pulses are 12v yet or not but it did look to be getting something.
I've read a lot about the tfi failing so I've got the special tool on the way so I can pull and test it next but figured I'd share my story in case anyone here has a good idea. Seems very suspect to me that it was a gradual decline flowed by nothing. Could the heat cycling in the tfi cause something like this or is it all or nothing? Buddy thinks maybe the hall effect sensor going bad due to weaking magnetization?
Thanks for any thoughts!
