- Aug 17, 2007
- central ohio
- 2.5 (4 Cylinder)
- Tire Size
- 235/70/16
- My credo
- the grey-t escape
the dimmer switch for the headlights used to be on the floor.
You have a pedal for the washer fluid too?
Why not?No it doesn’t... I wasn’t alive in the early 70’s.
Thanks Ron. I ordered an actuator rod from Amazon. Will probably tear into all that on Monday afternoon and Tuesday when I'm off work.Leave fuses out or battery disconnected
You can unbolt the ignition switch under the steering column(above brake pedal)
Pull it down and out, check that it slides OK and has START return spring working, so its not the problem
Plug it back in to its harness, and put switch in OFF position, 4 positions, ACC OFF RUN START
Hook power back up
Slide it to RUN and dash should light up, then slide it to START, clutch pedal down or Shifter in PARK
And it should start
You can use it this way but NO KEY REQUIRED, lol
Yes, you need to pull steering wheel and disassemble most the the steering column to fix an actuator rod issue depending on whats broken
Loads of videos on doing that, most Ford trucks of similar years used the same parts and setup
Got it done. Took all day. But no extra parts left over. I also replaced some plastic bushings for the column shift rod. I hope I never have to do that again.
Not really. I can do it again, easier and faster. But I would prefer not to. There are a couple steps that took some ingenuity.So what you are saying is, if that happens again your fix will be buying a different truck LOL.
Did that. The guy in the youtube video recommended filing down the new piece so it could be inserted without taking the whole assembly apart. I didn't like that idea. So I figured out how to get the other sliding pieces out of the column. Cleaned it all up and used new grease for re-assembly.If I remember right I took the whole colmn off the taurus and brought it in to the house to work on.
