Would like to know where the plug is on a 2.9L 4 x 4 to put the oil or grease into transmission .
Connie, I edited your profile so that your address is not visible. I did not think you wanted everyone to know where you live!
The fill plug is on one side of the transmission (driver's side if I remember right.) It looks like a large bolt.
You want to use GL-4 gear lube like everyone else has said, definitely NOT grease. I would try to use a synthetic gear lube if you can find one. GL-4 is kinda hard to find, synthetic will flow better at low temperatures and this is important for it to be easy to shift... I have 90w GL-4 in mine and it's VERY hard to shift in cold weather at first.
Then using GL-5 at the Pentagon could cause some real problems
Hopefully the terrorist don't read this thread
