2008 4x4 Ranger.
Dana
Newmarket, on.
New battery in key fob. Would appreciate advice on how to program same so it will sync with my car.
NOTE
NOTE: All Remote Keyless Entry (RKE) transmitters must be programmed at the same time.
  1. Before entering the program mode, the vehicle must be electronically unlocked with the RKE transmitter or the door lock control switch while the driver door is open.
  1. Turn the ignition switch from OFF to RUN 8 times within 10 seconds, with the eighth turn ending in RUN. If the module successfully enters program mode, it locks and then unlocks all the doors.
  1. Within 20 seconds, press any button on an RKE transmitter and the doors lock and then unlock to confirm thateach RKE transmitter is programmed. Repeat this step for each RKE transmitter.
  1. If the door locks do not respond for any RKE transmitter, wait several seconds and press the button again. If the door locks still fail to respond, referto Locks, Latches and Entry Systems in this section. Make sure that no more than the maximum number (6) of RKE transmitters is beingprogrammed.
  1. Exiting the programming mode is accomplished if 1 of the following occurs:
    • The key transitions to the OFF position.
    • 20 seconds have passed since entering programming mode or since the last RKE transmitter was programmed.
    • The maximum number of RKE transmitters have been programmed.
NOTE
    • Before entering the program mode, the vehicle must be electronically unlocked with the RKE transmitter or the door lock control switch while the driver door is open.
    • Turn the ignition switch from OFF to RUN 8 times within 10 seconds, with the eighth turn ending in RUN. If the module successfully enters program mode, it locks and then unlocks all the doors.
    • Within 20 seconds, press any button on an RKE transmitter and the doors lock and then unlock to confirm thateach RKE transmitter is programmed. Repeat this step for each RKE transmitter.
    • If the door locks do not respond for any RKE transmitter, wait several seconds and press the button again. If the door locks still fail to respond, referto Locks, Latches and Entry Systems in this section. Make sure that no more than the maximum number (6) of RKE transmitters is beingprogrammed.
    • Exiting the programming mode is accomplished if 1 of the following occurs:
Thankyou so much!
