- Oct 6, 2020
- 4.0 V6
- Total Lift
- None
- Total Drop
- None
- Tire Size
- 235/75R15
I have a 2003 Ford Ranger with pretty low mileage (80k) and it was given to me after someone had passed away. Before then, the truck had been sitting for 2 or 3 years, as he couldn't drive it. When I got the truck I got a fuel pump, fuel filter, but I never drained the fuel (1/2 Tank) and I tried adding 5 gal. of premium and a can of seafoam to at least try and get it started with the bad fuel. I can see that the fuel is making it past the filter, because when I pulled the filter to replace it, gas came out of both ends. The truck has compression, spark, and seems to be getting fuel, but it won't start, a couple days ago I started changing out the spark plugs, I have the driver side replaced so far, and I'm doing the passenger side today, even though all the plugs I've pulled so far seem to be alright. The second issue is, neither the radio or the OBD II port work, I'm going to check the fuses today, but if they aren't blown what could be the cause? The battery also seems to go dead relatively quickly even if I'm not messing with it. Also, when I was trying to put the fuel tube back onto the bed I dropped a screw down the fuel tube, and what would be the best way to get it out?
