aball4620
Hoping to get some fresh eyes on this problem. 2.9 starts up and then stumbles and surges while idling. Won't rev past about 2k. Fuel pressure primes to 36 and then sits at 29psi, increases when tapping the throttle, and bleeds down to almost nothing over 24 hours. I have an old, noisy high pressure pump and swapped it back in wondering if the high pressure pump was failing, but no change in symptoms. FPR is new and line is dry. Injectors are fresh remanufactured and I checked the spray pattern before installing. As for codes, the only one that shows up is 63 in KOEO continuous memory, which is TPS voltage out of range (brand new TPS).
Any help is very much appreciated - if you have any questions please ask. I've replaced a ton of pieces but I find that if I start listing them nobody responds to the original post.
