2.8L Header Flanges
D Lenz
Paulden,Az
Hello All
I am doing a custom build on a Ford Cologne 2.8L (74-79) and had one heck of a time finding header flanges ... so I designed/machined my own.
I designed them for 1 1/2" tubing (Hooker makes tubing and 3x inlet collectors) with a stop at the bottom which should afford good port matching and a positive stop for the tube to keep everything up tight.
I have fit them to the heads I have and everything seems to be OK but I will not be building the headers for several months (engine is not back from the machine shop). They are still a bit dirty so please excuse the big chunks.
Since I like sharing the resources, I am attaching the drawing files and a picture of the finished product.
As a side note: The drawings show a 'Z' drill for the bolt holes, however if one instead wishes a bit of a tighter tolerance might want to drill them using a 'Y' drill. The holes can always be opened up as needed.
Enjoy!
  • MT20-0712-01AA-DETAIL-1 - Sheet.pdf
  • MT20-0712-01AA-DETAIL-2 - Sheet.pdf
What keeps the header gasket from leaking at the bottom?
I guess I do not understand the question ... I made allowance so the air injector ports are blocked.
I think he's referring to the way the bolt holes are all on one side.
..... and the headers could not be tightened at the bottom because of no provisions for bolts. However, one may plug the emissions holes and , using the gasket as a template, drill and tap new holes at the bottom. I've done that to all of my 2.8 heads resulting in no "blow out" / leaking gaskets.
I planned to block off the air injector holes. As far as drilling lower holes, the old headers I built years ago only had the six bolt holes and were 1/4" thick, never had any leaks. These flanges are 3/8". Also small block Chevys only have bolts on either side of the exhaust tubes, however I guess time will tell. Thanks for the heads up.
Hello All
Enjoy!
How much would make some of these for?
Be sure to chase the the threads with a tap. Do that work clean, the bolts will be happer & not back out. Use copper or nickel anti seize, not the aluminum, on the threads & mating surfaces. Good work thanks!
Btw, I'd investigate using a symmetrical bolt pattern as that lower blank spot on the header flange. If you can get a fastener in the head there, even if it's a SAE 5/16-18 hole & thread, I'd do it. When it goes through a few heating cycles, it will pull away & eventually leak only because there is a bolt opposite.
Op hasn't been around since Nov '23. You may be better off taking the files he provided to a local metal shop, or an online service like SendCutSend. (I've never used SCS, just know that they cut metal to drawing.)
