- Jul 19, 2020
- Southern california
Thanks Dirtman. That makes sense.Non ford complete fuel pump assemblies, which is the pump, regulator, EVERYTHING. Are known bad. It's a massively known common issue with replacing fuel pumps. Not even just a ford thing, any car. Fuel pumps are very precise items and Chinese crap does not work. It's very tempting to go cheap but that spectre pump will die within a year. As will any knock off crap brand. Not my opinion, its widely known to most people on this forum and mechanics. I'd sooner take my chance on a oem fuel pump assembly from a junkyard then buy a aftermarket unit.
What @PetroleumJunkie412 has suggested is a pump only, meaning you have to do some work to fit it into the OEM assembly. You re-use everything and only change the motor. He has found a MOTOR ONLY that works well if you fit it to the OEM system.
So I would be in a better situation just replacing the fuel pump motor, or replacing the whole unit with the $700 ford unit. Makes sense...
I’ll see what she’s looking like after the fuel filter change if I get her back today. It will be today or tomorrow so I’ll be able to check live data once she’s back
