Ok to T off booster line for vacuum?
I hope you all get aids.
Yes, you can tee off the booster line.
Didn’t you have some odd-ball check valve setup?
I’d stay toward the intake side of that.
Yes, you can install a T on that line, won't hurt a thing
You can make your own vacuum and you get to burn things up too :)
Yea i figured that out. Its a equalizer, at low rpm it uses vacuum from the intake but at high rpm when intake vacuum is low it steals vacuum from in front of the throttle body or some nonsense like that. Its ment to keep the brake pedal "feel" even.
Im definitely putting the "T" directly off the intake and not in anyway part of that crap.
So.... You're a dog, then? As far as I know, only humans and dogs herd sheep. So, if you're not human, then you must be a dog.
Arf!
You sound delicious.
I...… Am...…. A...… Robot...….
Danger! Will Robinson. Danger!
