You would need to see what the ohms are on probe to know if other temp sensor will work
OHMS usually go down as temp goes up on these types of sensors
No you shouldn't have to rewire anything
The controller/relay activates the Fan Relay
The controller/relay and sensor are all that's in question because the Fan relay works, fan comes on
You haven't hooked up the Green AC wire yet, correct?
As 12v on that wire would activate fan
And fan goes off with key OFF, correct?
That means its wired to ignition OK
So either the sensor is bad, and BOTH being bad is a long shot, so Controller/relay is bad, best guess
hmm I was just gonna check it cold and hot for any variance....
you're right, looks like I can just yank out the controller part of it and just do the minimal wiring of the non adjustable unit (and new relay)
I did hook up the green wire, then disconnected it just to rule it out. Didn't make a difference.
I have the 12v source spliced to a key on only power source, so yes key off does kill the fan.
So far all signs are pointing to bad controller.
I tested the relays and they seemed good, but either way I'm gonna grab new a brand name one for the new sensor.
I found the same controller that came w/ my kit for $22 on ebay, so I think most of my money went into the nice fancy shroud and fan, which does cool down fast with a relatively low amp draw. Im not so butt hurt anymore about the bad controller....just annoyed about having another cycle of ordering and waiting for parts and being down in the meantime.
and after your guys' replies I may go back the 180 thermostat... have a plethora of various degrees left over from my temp issue fiasco...
My truck liked the 180, but many posts on here steered me towards the higher temp ones, and I went 195 because that was the factory motorcraft (and it had the bypass jiggler). the 180 hardly moved, my 195 is constantly moving regardless of driving conditions (thankfully not much anymore).
