What y'all think of my new suspension
4.6Ranger
kansas
42579
42580
42581
42583
You need to add some gussets. You have a panhard bar and no real crossemember. If you strengthen that shock mount similar to my scribbles, that should make it strong enough.
I will add a sway bar soon
That’s fine. But you should still add diagonal braces or gussets to that cross member you built. Otherwise, it will break from side- loading.
A sway bar won’t add any strength to a frame... You need a crossmember that keeps the frame rails from bowing in and out. The one you have won’t do that, but it can be changed to work.
I am assuming this is for a strictly street truck build?
This is just a street build no more off-roading
This is what @snoranger was pointing out. Maybe this helps.
42586
I would love to see a pic of your 4.6 in the engine bay
I don't have the motor back togeather yet
you should start a build thread so others can follow your progress. The 4.6 in a Ranger is still a pretty rare bird. especially one that is well documented. There are a few here with 4.6 Rangers but the build threads are less than informative. I am in the process of starting a 5.0 swap into mine, but thought about the 4.6 because there are at least a 100 in the JY at any given time while the Expo/Mounty 5.0's are drying up around here.
