- May 15, 2020
- Locust Grove Ga
- 2.9 V6
- Tire Size
- 235/R75/15
Working on 88 Bronco II has been parked 8 years(?). Replaced fuel tank, pump, high pressure pump, fuel filter,new injectors, pressure regulator,flushed fuel lines,cleaned rail,plugs, wires, cap, rotor,coil,ECM/ECA, everything but pick up in distributor, by passed inertia switch to test. Cranks runs shuts off. Cranks again run only a few seconds cuts off. Third try only turns over. Wait hour or so same thing. I need help.
