Good image, can you access FRP or FP duty cycle? Fuel trims are crucial too as noted by acsnowrider. Do you have a BARO value too?
should not be noisy unless they are failing or cheap.
Yessir!Just the dip behind the throttle...
Could be, I've spent 32yrs in dealerships and most pumps sound good, smooth snd quiet, some do sound loud and those I do not have much faith in. A good,factory pump can go for 20yrs or more, keep the filter clean and gas good. Ultimately the noise is a sigh of imbalance of some form within the pump, imbalance leads to issues over timeI guess my original fuel pump has been failing since it rolled off the assembly line 11 years ago.![]()
Call your mother."Massive pump" sounds like a punk rock band.
In the middle of finishing up an install of a 340lph pump because too lazy to diagnostics, and had to go to a bigger pump for blower anyways
