- Jun 27, 2018
- Cape coral FL
- My credo
- Do unto others...
It was late earlier when it happened as I was about to go on my way home so I didn't check anything, just caught a ride from a friend so I don't know if there's anything obvious like a leak. Is this something that happens often enough with a common cause? I'm not too familiar with the clutch system, I just know it's hydraulic and after a couple youtube vids learned the slave cylinder is a b@#%! to get to compared to the external type. Hopefully it's not that. Lol I'm at the stage I'm first trying to pick a problem to hope for. Like hopefully just a line that's easy to swap out. Anyway, so what's the likely culprit if there is one? Is the whole system easy to inspect from underneath? I'd like to get the best idea possible of what's going before taking to mechanic. I'll check it out in the morning and can report back asap any needed info. Thanks!
