- Oct 1, 2019
- Central City, NE
- 2.9 V6
Well the girlfreind says she doesnt like having to slam my doors, so does anyone know how to adjust them to shut easier?
without knowing more details, the first place I would start is at the door Hinge. Some models have a plastic shim that wears out over time, causing hard to shut doors, some requires a little "lift" when you shut them to actually close. Check that shim, and go from there. No real adjustment can be done to the doors, nor should be done. That plastic shim/bushing at the door hinge is the first point of failure for many Ranger and Mustang doors.Well the girlfreind says she doesnt like having to slam my doors, so does anyone know how to adjust them to shut easier?
they don't have to be lifted to shut the door, they just wont shut all the way without being slammed. I'll check the shims on the hinges.without knowing more details, the first place I would start is at the door Hinge. Some models have a plastic shim that wears out over time, causing hard to shut doors, some requires a little "lift" when you shut them to actually close. Check that shim, and go from there. No real adjustment can be done to the doors, nor should be done. That plastic shim/bushing at the door hinge is the first point of failure for many Ranger and Mustang doors.
I know ppl have done this, but I didn't think FORD meant for adjustments to be made there, IMO this is a HACK not a fix. but to each their own I guess. I had the same problem with my mustang. I didn't HAVE to pick up on the door, if I slammed it hard enough, but picking up on the door made it easier to shut, without slamming the door.Actually, the striker plate where the door latches to the body can be adjusted by loosening the torx bolt and tapping it in towards the interior (or out away). I do this to stop the doors on my 30 year old truck from rattling. I also replaced the missing plastic bushing on the round pin of the door latch with a piece of plastic tubing and that also helped with rattles and the doors close easier. They will never be as easy to close as my late model Tacoma because they are light and ancient.
Has the latches ever been lubed? Spraying some white lithium grease into the mechanism might be in order. Make sure you wipe off any residue that may accumulate on the striker after you are done. Most females really hate it when grease and stuff get on their clothing.
But i like this oneYou need a stronger girlfriend
Don't you mean close it for her? Although the opening it would prob earn brownie points too.Open it for her![]()
