- May 28, 2018
- 41N 75W
- 2.3 (4 Cylinder)
- Total Lift
- It's up there.
- Total Drop
- It's down there.
- Tire Size
- Round.
- My credo
- I poop in the furnace.
I'm not a scientist... that's just my understanding on how it works. If the gas doesn't completely vaporize in the combustion chamber you get more unburnt fuel going through the exhaust. Winter fuel is designed to vaporize better to burn completely in cold weather and those additives they use to make it do that somehow lower it's energy.
Your right about physically using more fuel in the cold, dense air means more fuel to reach 14.7:1 fuel air mix. The maf/map tell the computer the temp, flow and density of the incoming air. The computer says "you need this much fuel for a perfect mix" then the o2 sensor says "hey computer, your an idiot there's still unburnt fuel down here" and the computer adjusts again and leans out the mix.
But if it did that with summer fuel thats not burning right in -20 degree weather it would end up making the engine run too lean and possibly damage it.
Again not a scientist, no idea on specifics... that's just how I understand the principles of the winter vs summer fuel nonsense.
