Rizzo1130
- Oct 1, 2019
- Age
- 47
- Valdosta Ga
- 2.0 (4 Cylinder)
Stumped... Cleaned carb and drained tank
I get it to crank for just a second while putting gas in the carburetor but it immediately dies. In the idle speed control module on the fender well looks like it's melted so I'm going to get a new oneAuto speed control? Not sure what you mean.
Either way - no, won't stop it from cranking. What exactly happens when you try?
You're right sorry about that.Clarification of terms:
Cranking is the starter's electric motor spinning the engine using the battery.
From your last post, it sounds like you're saying that it -does- crank just fine, but that it'll then fire for a moment and die?
I did it to try to fix the problem. It hasn't been ran in aboutAnd this started after you cleaned the carb and drained the tank? Or did you do those things in an attempt to fix the problem?
I'm pretty sure the choke is not working. But it always crank regardless. I don't know I'm thinking maybe fuel pump?Assuming it will run fine if you manually provide fuel or starting fluid, then you definitely have an issue related to the carburetion system. Is the choke working properly? Can you manually hold the throttle partially open and try to start it?
I will try both thank both of y'all for applying I really appreciate it.Disconnect the fuel line and crank the engine. Does fuel shoot out? If it does then your carb is just stuck. Old gas sitting in it for a year will do that... spraying some cleaner at it wont be enough to fix.
