- Jun 21, 2008
I've been doing a ton of stuff to this Ranger to try and keep fluids from leaking.
I bought it off a guy who swapped out a B2 motor in order to sell it. It's a good runner but needs some TLC
Here's what I've done so far:
Repaired leaking P/S return line (at steering shaft)
Repaired leaking P/S high pressure hose (at P/S pump)
Replaced broken driver side passenger window button
Replaced blower motor (cleaned out clogged ducting that kept the "max a/c" damper from closing as well)
Repaired air cleaner assembly
Auto trans filter replacement and new gasket installed
Radiator flush
Tune up (plugs, wires, distributor cap, distributor rotator, fuel filter)
Replaced all belts
Replaced driver and passenger lower seat belts
Replaced ash tray mounting bracket
Paint wiper arms and replace with custom blades
Install new battery tray
Replace A/C wiring harness
Replace sun visor mounting rods
Replace passenger and driver outside mirror
Replace rear view mirror
Here's what needs fixing ASAP:
A/C system diagnostic/conversion (R12 system not converted and previous owner dumped in 150+ PSI [low pressure side reading
] of R134...clogged or broke something in the system)
Radiator replacement (small leak)
Replace all hoses
Here's what's on deck:
Brakes
Replace all window weatherstripping
Replace passenger and driver door handles
Replace tailgate handle, latches and cables
Replace front grill
Replace rear tail lights
Install grill guard
Install fog lights
Install baja lights
Replace bed liner
Install custom accelerator and gas pedals
New front bumber
Paint roll bar
Paint entire truck (including minor body work...dents and dings)
Wheels and tires
Shocks/Struts (?)
Stereo
Alarm
Once this motor goes (or whenever I get the major itch) I'll drop in 5.0.
Pics coming soon!
Radiator flush
Replaced all belts
Replace all hoses
Brakes
Replace front grill
Install grill guard
Install fog lights
Install baja lights
Replace bed liner
New front bumber
Paint roll bar
Wheels and tires
Shocks/Struts (?)
Stereo
Alarm
Pics coming soon!
