2000 Ford Ranger 4x4 Not Engaging
bpagut
South Amboy , New Jersey
So I recently went down a trail and attempted to turn my 4 wheel drive on. It did not engage nor did the light on the dash turn on. When i start my truck, the 4HI and 4LO lights both turn on then turn off on the dash. Whenever I try to turn on the 4wd the lights dont come on and i cant hear any clicking or hearing of the transfer case even trying to engage. I believe it is something electrical but I cannot pinpoint it. Any help or advice would be greatly appreciated.
Welcome to the forum
The 4WD lights coming on with the key is a Bulb Test, nothing more.
In 2000 you may still have the 4WD system that is run by the GEM(generic electronic module) and PVH(Pulse Vacuum Hubs)
OR
You could have Live Axle and a 4x4CM(control module), all 2001 and up Rangers had this, but transition was during 2000
So first thing will be to see which one you have
Picture here of PVH hub: https://i.ytimg.com/vi/SLWsG0v3jas/maxresdefault.jpg
Picture here of Live Axle Hub: https://i.ytimg.com/vi/yM3Obly5IHg/maxresdefault.jpg
So obvious difference
Normally if the shift motor(on transfer case) stops working the 4WD lights will Flash when you try to shift to 4WD, than means the "controller" is working but motor isn't moving.
So most likely cause of the problem, as you described it, is the "controller" but we need to know which one you have to go farther
OR
I have a GEM as I had pulled out my dash and checked the 4wd selector switch. Could it be possible it’s just the transfer case shift motor not working ?
I’m not sure thought if I have a gem if I still have a 4x4CM. Where would it be ? I checked the passenger side kick panel and found nothing.
Not clear yet on what you have but
IF the 4WD switch wires connected to the GEM then you "had PVH" hubs and someone locked them and removed vacuum hoses
So you don't have Live Axle just locked hubs
4WD lights should Flash if shift motor is not working and GEM is
There is another part with the GEM 4WD system, it would be behind the GEM module closer to firewall, thats the 4WD relay box
It has 2 relays inside that connect to the shift motor, GEM operates the relays to send voltage to the motor, these are the Clicks" you may hear when system is working.
But again if you select 4WD and GEM activates the relays but motor doesn't move the 4WD lights on the dash will Flash.
Since there is no Flashing I would suspect GEM is the issue, not relay box or shift motor.
But GEM modules didn't fail that often, so rare but not unheard of
If you have Live axle not lock/unlock front hubs then you have a 4x4CM, GEM is there but not used for 4WD
4x4CM will be in/behind passenger side kick panel, 2000-2003
Looks like this: https://wholesale.tasca.com/graphics/ChannelAdvisor/Photos/Ford/Watermarked/6L5Z7E453A/0.jpg
Says 4x4CM on the label
These were known to fail.
2001 to 2005 Ranger or Mazda B-series will work as replacement, not 2006 or up
Ford part number is 1L5Z-7E453-AB, or -AC
Dorman has them as 599-252
