Ok heres what i came up with...
Now granted the truck was still cold, and it only acts up when warm...but...i know electronics can break down as they heat up...
On a regular old charging system test, no load, i got 14.2V at idle, no change with RPM.
Charging system test, under full load (headlights, heater, etc) it dropped to 12.2V, when revved it slowly climbed to around 13.9, then began to drop, to around 12.9, then back to 13.3 or so.
Tested for AC, got .20, then 0, then .21 and the rythm repeated, engine revs had no effect. With engine off i had no AC volts.
I also noticed my neg battery cable is almost worn in half.
Im thinking the alt is shot for sure, i need to get one of those cig lighter things to see what it does when it acts up. Turning on any heavy electric puts a noticable bog on the motor at idle
Thoughts?
