- Sep 21, 2017
- Mississppi
- My credo
- Break it right the first time. Fix it better the next time.
it wont.
the 2.9 is already a hi-rise.
put a rubber plumbing cap on the tb opening...
cut hole in top and build adapter....with a tin diffuser bridge over the 3-4 port directly below the carb.
you can do this with a roll of gasket material...some sheet metel...a hack saw...drill and some hardware...maybe a lil epoxy.
bridge the high pressure pump with a fuel filter and unplug it...
if i were a carb guy....cake job.
that or put a propane carb on the throttle body and run propane.
unfortunately....it wont ever run as good as efi.
and trouble shooting mechanical issues is a completely different set of headaches.
That is some good info right there.
