- Jul 6, 2018
- Vincent Ohio
I have a v8 bored 40 over cam but son doesn,t remember size and a aod transmission.What rear eND should I use for decent power and decent mileage?
OK what gearing should I use? What ever a ranger two wheel driveI don't think rear end is what you should ask about, you should be concerned about gearing. It really depends on intended use, vehicle weight, tire size, usable rpm...
I forgot you said V8. You could easily go with 3.42 or even 3.31 without it feeling sluggish. I don't know how common those ratios are. I know 3.55 and 3.73 are easy to find
This message composed solely of recycled electrons. Go green!
3.55 would also be my recommendation.
I have a 3.50 gear set in my F150... with just the stock 5.0 and a 4 speed manual, it's pretty snappy. I think it's a good overall ratio, I'd think your light Ranger would make for a fun ride and the AOD overdrive gear will help a lot on the highway. 3.73 would be another good one if you want a little more on the low end and aren't as concerned with your RPM on the highway. 3.55 and 3.73 are very easy to find in 91-up Explorers, and you get 31 spline shafts and limited slips were very common. I'd be very tempted to do that although a 7.5 or Ranger 8.8 would be OK.
2wd daily driver with V8 - I would go with the 3.55 gears. Limited slip would be nice for that also.
You do have to fab mounts or use a flip kit to mount the axle though.
I cut the spring perches off carefully and reused them for my last 8.8 swap, and used shock mounts from a 7.5. I also sliced off the sides of the u-bolt plates and reused them from the 8.8. The only thing I really had to buy was new u-bolts - axle tube is bigger than a 7.5 and they needed to be 2" longer than stock. Fortunately AutoZone has universal ones that will work and are less than $20 for a full set.
I'm kinda anti rear disc brake conversions these days, if the recipient had drums before it's so easy to just hook up the e-brake cables and be done with it.
