Junk Collector
⭐Supporting Member
Truck of Month
What book do you have? Those diagrams look way better than anything I have access to in my Haines or Chilton books.
That is a Ford EVTM.
No those wires do the same things in both systems. The difference comes in with where the warning device is in the circuit.
The idiot light is a bulb in line with the circuit that turns the alternator on and off.
The ammeter, is in line with one of the lines back to the battery. It has to be, or it can't really be a whole system ammeter. For an to be a true one it has to have basically all the power to and from the battery go through it
I know with my tractors you pop the dash apart and it is all right there in the open.
The system still had freon in it so I think I am good for leaks. When I get it stuck together we can pull a vacuum on it it and see how it holds.
I am getting new hoses especially since I am going to have to alter them to work on my conglomerated truck.
It is getting flushed for sure, getting converted to R134A too.
It is interesting how different your third gen is from a second gen, they still had separate hoses. Yours is more like the Explorer.
I can't believe how freaking hot it is here in the east!
The suction line dips down and is held in place just above & right of the thermostat housing. I'm not sure but I think they run the suction line intentionally above and behind the radiator because they want the Heat to hit it and prevent slugging (saturated gas and or liquid refrigerant) of the compressor
Are you going to paint it? I don't know that it makes sense to paint a condenser flat black but they often are. It would certainly look better LOL
I wouldn’t paint it at all.
That factory paint on the condensers is very thin.
Painting it would put a think coating on it and prevent better heat transfer.
I'll be fine and less obvious if it's black,. It's giving up heat, not absorbing it.
