DLog
Has anyone had any success with installing a 360Fe in a 1993 ext cab 4x4? Found what I think would be a great deal on one just wanna make sure it will fit.
I am wanting to do the 302 swap but I found the FE motor and c6 for $250. Since the 302 is easier and has been done more I'll stick with that. Thank you Rusty ole ranger for the info... you answered my question.Anything will fit with persistance and a sawzall. Its been a while since ive seen an FE in person, but IIRC they are roughly the same size as a 335 series (351C/M/400) which in themselves only slightly smaller then a 460.
Unless you are going for orginality, and you want a bit more snap then a 302, i would think a 351W would be somewhat eaiser, plus its been done.
If you do want an FE, id go whole hog with a 390. Or install the 390 rotating assembly into your 360.
Im sure steering clearence, as well as radiator/fan clearence would be the biggest obstacles. Next would be the weight of an FE, but a set of 150 springs (minimum) or 250 (what id reccomend) would fix that.
Youll need to make motor mounts, and do some smash bashin on the trans tunnel. A C6 wont fit a factory tunnel on an RBV IIRC. A 4 speed might work, but to my knowledge theres no 5 speeds thatll accept a T case that will mate to an FE, i could be wrong though, or you could run an divorced case.
But to my original point, if your going for original, have at it (i personally think its a cool idea, even though im not a huge FE fan), on 2nd thought, a 400 would be just as much work, and will create massive torque when done right, and still be original...
But a windsor would be the easiest if we are talking in the 350-400CID range.
Sent from my SM-G955U using Tapatalk
Will the c6 bolt to the 302? If so I may just ask him what he wants for the trans. Get the tail and the transfercase later.Happy to help
250 bucks is about what a C6 would go for (if its good) by itself. The 360 is one of those engines no one wants, cause when it goes bad a 390 drops right in. Kinda why the 351M/400 are a dime a dozen, cause a 460 bolts right in. Even though, from a reliabilty standpoint, and in my opinion, the M engines walk all over a 460.
Don't short sell the 360, the block is the same as the 390, only the rotating assembly was different. As for the 351C, 351M & 400 being the same physical size, that's not true. The 351C was shorter and narrower and used the small block bellhousing pattern, along with the same motor mounts.Happy to help
I wasnt selling the 360 short, just saying why use a 360 when you can have a 390? The 360 was a decent engine, as was the 390 (athough personally ill take a 351M/400 given the choice)..
Sorry, I just didn't want him to get the idea the 360 was worth less than a 390 as far as selling it went. At this point in time, FE's aren't exactly plentiful as they once were. A good FE block nowadays don't grow on trees.(me personally ? The 351M was and always will be a turd, now where near on a par with the 360 )
