INFO Photos of different wheel/tire sizes on stock and lowered 2WD's
I have Cragar SS Mags 15 x7 with P235/70R up front 15 x8 with P275/60R on the rear. Get lots of compliments on the Cragars.
guys i have a problem, i want know what size of tire and wheel have to get for my ranger if got 3" lift, i got 35x12.5, 15 right now and looks great but is 2 slow, i want to know what i have to do. o sorry my ranger is 3.0 4x4 94, thanks
aero wheels
front 15x8 bs 4" 235 65 15
rear 15x10 bs 5.5" 28x12 sportsman sr
Its a stock 4.o 5 speed auto with 3.55 posi
Stock suspention 2wd 92 reg cab longbed. Jeep wrangler rims 15x6 tires are 235/75/15. Slight rub on front sway bar at full lock. 2.3 engine, manual trans, 3.73 gears
98 Steppie
Put my 15x8 Canyon wheels with 225/70's front & 275/60's rear on my 98 XLT Steppie:
I have found this website and others like it extremely helpful in picking wheels for my ranger. I thought I should contribute because it was so helpful.
I decided to purchase Cragar Soft 8's in silver. I chose 17x8 wheels. They are 4" back space and zero offset. I believe that essentially means that where they mount to the truck is in the very center of the wheel.
For tires I went with 235 65 17's. I used a tire size calculator to compare these to stock in order to determine how much taller and wider they would be. The overall diameter increased by 1.63 inches. The new tires are 0.39 inches wider.
I went with this size because I wanted to fill the wheel well up a little more with rim and not tire. I wasn't looking to raise the truck per se, just give it a more modern look with more rim than tire. I also did not want to go with fancy aftermarket wheels. I can really appreciate the stock look of a truck and chose these wheels because they are found on many trucks with stock wheels. ( mostly gmc and Chevy work trucks but..)
Stock 15s with DJM 4/5 drop.
Rear test fit of 2012 Mustang 18x8 factory option wheels. Spacers will arrive Thursday so I'll mount them all. I'm getting antsy.
Stock suspension 1998 ford Ranger XLT with 275/60/R15 on 8 inch rims -19 off settruck - Copy.jpg
:yahoo: not bad for an old truck it has some rust but still rocks pics of truck kinda suck taken with I- Phone but these are rims and tires
235/75/R15 Goodyear Wrangler Radials I pulled off my YJ.
Stock 15x7 wheels with 4.5" backspace.
I'm probably going to go back to 225/70/R15 and put these back on the Jeep.
IMO the smaller tires on the truck made it feel like there was more 'get up and go'.
A while back, I was considering a set of Ford Flex rims for the truck, but didn't want to have to bore the centers or get spacers installed so I went with the American Racing rims pictured above. But they would have looked good:
15"x6" Vision HD steel trailer wheels with 215/70R15 Cooper Cobras. Backspacing is 3.5", zero offset.
1991 Ranger 2WD at standard ride height.
26184
