Rangerfireman383
Guys, my truck has always had a random intermittent issue of cutting out. I recently decided that I had enough, after it got to where it wouldn't stay running if I cranked it up to let it warm up in the morning. Initially, I ran a koer and koeo test which gave me several codes ranging from bad pip sensor to bad ect sensor, to bad iat sensor. I have replaced the iac control valve, ect sensor, iat sensor, complete distributor, and lift pump assembly in the tank(fuel gauge was acting crazy too). I also went through and cleaned all grounds, and took the computer apart and checked for any obvious signs of issues and found nothing. I suspected that it may have low fuel pressure, but it immediately goes to 30lbs on start. Fuel pressure regulator is good. It takes an extended period of time to get it to start when cold, and once it does, it surges and cuts off several times before I can get it to stay running. It also cuts out randomly while driving, and I have also noticed that if I am running the headlights, and switch the heat on, it will stumble and sometimes cut off. I am getting pretty frustrated with it and am hoping someone can help me figure it out. I am thinking now that it may be a wiring issue somewhere. Sorry for the long post, but I'm trying to not leave any details out. Any help would be greatly appreciated.
