explorer sway bar
AzLizard
TUCSON, AZ
1985
I have a 94 xplorer was told it has 5 1/2in lift.
it has stock sway bar.
Was wondering what you all are doing? Extending, leaving stock, removing all together?
I assume you're asking about the front swaybar?
I removed it altogether from my BII... My Ranger I put disconnects on, though I've found myself leaving it disconnected more than connected.
(rear bars are gone entirely on both)
Explorer is probably top-heavier than my Ranger, so disconnects might not be a bad idea.
Jeep Wrangler (YJ) or CJ disconnects appear they will fit, or just make your own using drilled bolts & small hitch pins.
I run the front one on my lifted Explorer. My buddy doesnt on his, and the body roll on the street is terrible. Yes on mine it does limit articulation some, but its not a trail only rig, so I live with it.
It still works somewhat though...
Hey man how's things going?
Are yours extended or stock?
Mine needs to be streetable also as well as tow my camp trailer.
I used the extended links that came with the lift kit. They are not disconnects, but it makes it street-able.
We are doing O.K. still kinda up in the air on which transplant to do (kidney or kidney/pancreas). had a meeting with the hospital the other day and Im kinda leaning toward just doing the kidney (less stress on the body and less chance of complications). Other than that just surviving....Hope all is good down there.
I drilled and pinned a couple bolts for now.
You been waiting awhile.I hope it happens soon.
Surviving about it here too. Work dropped off and not looking good.
