- Sep 24, 2012
Still tracing wires. And there is a wire from the trans range sensor that leads to the ignition module. So I removed the distributor and the module and found motor oil covering the back and burnt. Now since the module could have suffered some internal damage by getting baked with oil. Could maybe this be causing my issue. Not getting a proper signal. I'm not sure which direction the signal goes. I'm assuming it goes from range switch to distributor.
Can any confirm or disprove my theory. I've all ready placed an order for another distributor and module
