- Sep 24, 2012
I've put another pcm in it. Tps is new. But I will do this test in the morning. I will write back on this early. Like 730 my time. I live in utah
Hooking up Vehical Speed Sensor (VSS) wires(optional)
There is a differential signal called VSS (Vehicle Speed Sensor) which comes from a small sensor on the transmission where the speedometer cable is connected. In 1986-1988 MAP cars this signal was used only by the cruise control and the sensor may not be installed if your car does not have cruise control. In MAF cars, this signal is used by both the cruise control and the EEC-IV. The wires/pins for these signals are not physically equipped in a MAP car's wiring harness, which will yield an error code for NO VSS SIGNAL- (code 29) from the continuous memory codes in the EEC-IV. These signals are not absolutely needed, though some people have reported stalling when coasting to a stop without them. You can hook the VSS signals up to the EEC-IV connector by connecting the input pins of the EEC to the appropriate wires on the cruise control module (located just to the left of the clutch/brake pedals). You need to hook the dark green/white wire going to the speed control to pin 3 of the EEC, and the orange/yellow wire to pin 6 (these are the colors for an '88, anyway). These positions on the EEC connector are empty and will require 2 EEC-IV connector pins.
