2002 coil spring 5.0 ranger build
JakeF
10+ Year Member
Hello everyone finally decided to join the forum and start a build thread. I have been studying this forum for over a year I've seem some really talented people on here I am by no means building this to be a "new" truck but a "fairly nice" one is good enough for me I mainly want the 5.0 power in the small package but I will take the time to straighten out the dents and dings for a nice jet black paint job thanks for looking and I'm happy to hear any advice or comments.
Pics and save the pats effort get a 97 explorer donor
I actually had a 97 ex I used as a donor it is awd I will be converting the trans to 2wd. I am having a difficult time uploading photos off my phone any suggestions would be great
We can't wait to see some of your photos. Good luck with the build and thanks for sharing with us all. Most of us use a photo sharing/hosting web site such as Photobucket. You can try posting your photos there and linking them to your thread.
If your using tapatalk you can click the up arrow in the reply box then click the camera picture select gallery and pick the photos thats how i do it with an android not sure if iphone is the same
Id look for a 2wd trans or make sure you have the tail housing with the speed sensor and if you go conversion route pick up a rebuild kit for the trans its gonna be taken all the way apart to swap output shafts
20150605_144608_zpsuqggvirb.jpg.html
OK I will definitely be converting it and rebuilding does sound like a good idea since it will be disassembled. Will a tailshaft and output shaft work from an aod? I was under the impression most parts like those will interchange with aod, aode, 4r70w.
That im not sure but some one has an answer on that
Yes, it will interchange. Another option is to install a front diff and go 4wd/awd...
SVT
Yes I thought about that but I would have to get a solid axle to get it to work with the coil spring truck, I do have the front different from the ex.
Sent from my SM-G900R4 using Tapatalk
I installed tapatalk it still won't work for me I have android it loads up to 70% and quits
a>
Mocked up the Explorer rearend with explorer springs I was surprised to find out the springs bolted up flawlessly I think I will be using the ranger springs 8n the build though
